Java — Quick Start
This tutorial walks through creating a GroveStreams user account, an organization, and Java code that uploads random numbers.
Step 1: Create a Free User Account and Organization
GroveStreams - Create User Account
Open a browser and navigate to the GroveStreams registration page and sign up.
GroveStreams - Create Organization
You will be prompted to create an organization. Select Yes.
An organization is a workspace, typically representing a business, department, or project. Each organization has its own set of components, streams, dashboards, maps, and other items. An organization allows you to control user and API access to the organization. You are automatically the "owner" and given full access rights when you create an organization. Other users may invite you to their organizations with rights they give you. All of the organizations, you "own" or are a member of, will appear in your GroveStreams start page (the first page that appears when you sign in).
1. Enter a name for the new organization. It can be any name.
2. Click Create Organization.
3. Enter your new organization by clicking on its name.
Step 2: Find your GroveStreams Secret API key for your organization
GroveStreams - API Key
Step 3: Create the Java Stream Feeder
The GroveStreams API is RESTful and can be used from any programming language. This example uses Java with the simple Feed PUT API, which does not require JSON.
We highly recommend downloading and installing a free Java editor such as Eclipse.
1. Download and run Eclipse
2. Create a Java Project in Eclipse
3. Create a Java class called HelloWorld and copy the code below to this new class file
4. Right click on your Java Project and choose Build Path - Configure Build Path, click on the libraries tab, choose Add JARs (or Add External JARs, depending on where you placed the required libraries) and add the required library jars
Required Libraries
commons-codec-1.4.jar
commons-httpclient-3.1.jar
commons-logging-1.1.1.jar
These libraries are free and can be found online at: http://commons.apache.org/
Code (Don't forget to replace the api_key token in the code below with your Secret API Key!)
import java.io.IOException;
import java.util.Random;
import org.apache.commons.httpclient.HttpClient;
import org.apache.commons.httpclient.HttpStatus;
import org.apache.commons.httpclient.methods.PutMethod;
public class HelloWorld {
    private static final String api_key = "YOUR_SECRET_API_KEY_HERE"; //Change This!!!
    private static final String component_id = "myOrg.helloWorld";
    public static void main(String[] args) {
        PutMethod putMethod = null;
        try {
            // Connect to GroveStreams
            HttpClient httpClient = new HttpClient();
            while (true) {
                Random rand = new Random();
                String url = String.format("https://grovestreams.com/api/feed?api_key=%s&compId=%s&random=%f", api_key, component_id, rand.nextFloat());
                putMethod = new PutMethod(url);
                putMethod.setRequestHeader("Accept", "application/json");
                putMethod.setRequestHeader("Content-type", "application/json");
                //Upload the sample
                int statusCode = httpClient.executeMethod(putMethod);
                if (statusCode != HttpStatus.SC_OK) {
                    System.out.println("Upload to grovestreams.com failure: " + putMethod.getStatusLine().toString());
                } else {
                    System.out.println("Upload to grovestreams.com succeeded");
                //Sleep 10 seconds
                Thread.sleep(10000);
        } catch (IOException e) {
            System.out.println(e.getMessage());
        } catch (InterruptedException e) {
        } finally {
            // Release the connection
            if (putMethod != null) {
                putMethod.releaseConnection();
Step 4: Run the Script
The easiest way to run the script is to run it from within Eclipse.
Right click your HelloWorld class and choose Debug As - Java Application
Step 5: See Your Results
View Stream
1. The notification button will indicate if you have any notifications. Some notifications report errors. Check for any notifications that may contain any upload errors.
2. Select the Components folder.
3. Click the Refresh button.
4. Your new component will appear under the Components folder. Select and double-click a stream.
5. The stream's latest measurements will appear within the Quick View panel. The Quick View panel will display No Data if no measurements have been uploaded.
6. Stream Viewer. Explore a stream's historical measurements and its latest measurements. Select different cycles to zoom in or out.
Congratulations! You have created a simple Java data ingestion script.
Click on the Dashboards tab to create dashboards and maps. Right click on the component and choose Edit Component to set your component's location, add stream units, create events with notifications, and change other properties. Keep exploring and learning!
Watch for errors in the Eclipse console pane. Successful API calls return HTTP status 200 OK. The console will show "Upload to grovestreams.com succeeded".
If the call made it to a GroveStreams server, but an error still occurred, a GroveStreams system notification will be created that contains the error. While in the GroveStreams organization's Observation Studio, click on the Notifications button located in the top toolbar (It looks like an envelope) and select the System tab. Click Refresh to list new notifications.
Any parameter that is part of the URL needs to be URL encoded. This should only become an issue if you have given any parameters a value with reserved URL characters (such as spaces or commas). There are many free URL encoders on-line that you can use to encode your URL or URL parameters such as freeformatter.com.
Troubleshooting Checklist
  • Did you remember to change the api_key value within the Java code above?
  • Have you checked your GroveStreams organization for any notifications?
  • Is the Eclipse console showing errors?
  • Still can't figure out what's wrong? Delete your GroveStreams organization, start over, and follow the instructions carefully. Sometimes it's easier and faster to start over than to try and figure out what step was missed or performed incorrectly.
Still having problems or you wish to modify the solution and are not sure what to do?
Send us an email and we'll do our best to help: support@grovestreams.com
Helpful Links
GroveStreams Help Center
