API Example: Organization Backup
This script backs up an entire organization. The backup is a .zip file and is downloaded locally. An api_key cannot be used since content rights are restricted to user credentials only.
# GroveStreams.com Python 3.7 Example
# Demonstrates getting a session token and backing up an organization to a local file
# License:
# Copyright 2019 GroveStreams LLC.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at: http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import requests
import datetime
def checkResponse(response):
    if response.status_code != 200 and response.status_code != 201:
        if (response.reason != None):
            raise Exception("HTTP Failure Reason: " + response.reason + " body: " +  response.content.decode('utf-8'))
        else:
            raise Exception("HTTP Failure Body: " +  response.content.decode('utf-8'))
def main():
    #CHANGE THESE!!!!!!
    userId = "brucelee@acme.com"
    userPwd = "wingchung"
    org = 'af5da88b-1487-3873-a7c4-5ea69d867f3a'
    backupFile = "/home/gs/gs_backup_" + datetime.datetime.now().strftime("%Y-%m-%d %H:%M") + ".zip"  #This is a linux directory. Change it to a Windows directory if that's what you're using
    # Login and request a use session token
    url = "https://grovestreams.com/api/login"
    data = {
       "email": userId,
       "password" : userPwd
    response = requests.post(url,json=data)
    json_response = response.json()
    if (json_response["success"] == False):
        raise Exception(str(json_response["message"]))
    session = json_response["sessionUid"]
    #Download the Backup File
    url = "https://grovestreams.com/api/organization/backup?org=" + org + "&time=&exportAll=true&compDir=&contentDir=&session=" + session
    chunk_size = 100000
    response = requests.get(url, stream=True)
    with open(backupFile, "wb") as fd:
        for chunk in response.iter_content(chunk_size):
            fd.write(chunk)
if __name__ == "__main__":
    try:
        main()
    except Exception as e:
        print(str(e))
# quit
exit(0)
