REST HTTP API Conventions
What is RESTful?
A RESTful API is an application programming interface (API or web API) that conforms to the constraints of the REST architectural style and allows for interaction with RESTful web services.Security
TokensA GroveStreams HTTP API token is an security identifier that is passed with an API call as a query string parameter or as a cookie. When passed as both a parameter and a cookie, GroveStreams will use the parameter token.
Tokens:
- org
- This is the uid of the organization the API call is for.
All organization calls need this token only if the session token
is used. api_key calls do not require the org token as the org is
inferred based on the organization the api_key resides within.
- session
- The session token is created during the POST login or
POST login_guest resource calls. The user credentials passed to
the login resource will be associated with the session uid to
determine access rights for each API call. Session tokens will
expire during long time periods between API calls.
- The api_key token is used for cases where a user email
and password should not be hard-coded or stored in a file.
Api_keys should be used inside devices or external web pages that
make API calls to GroveStreams. Api keys can have very granular
API rights assigned to them and can be restricted from devices
with specific IP addresses or from specified domains. The api_key
token is not the
api_key resource UID, it is the api key's secret key. API keys
are created and managed by a GroveStreams organization owner. The
org token is not required when the api_key token is being used.
Two flavors: an api_key can be configured with or without a Run As User — the choice changes how rights are checked on each API call:
- Resource api_key (no Run As user) — the key's
resource + METHOD ACL is the gate. Each call's path and HTTP
method are matched against the key's resource list before the
handler runs. Best for narrow, device-style credentials where
you want explicit endpoint-level scoping (e.g. "PUT to
feed/{compUid}/*only"). This is how api_keys have always worked. See api_key resource documentation for the resource grammar. - Run As api_key (Run As user set) — the key authenticates the call as that user. The user's groups, capabilities, and folder / component permissions become the data gate (the same CrMgr code path used by a session-authenticated call). The resource + METHOD ACL is skipped — the key's resource list is ignored on every request. IP and domain restrictions on the key still apply. Useful when you want one stable credential that exercises a specific user's permissions across the HTTP API (feed PUTs, component / stream calls, GS SQL queries, etc.) without hand-curating an endpoint-shaped resource list. Required for ODBC/JDBC connections (see ODBC/JDBC docs). Not supported for OData — OData uses the Add Instance flow for folder-scoped access; see the OData docs.
- OAuth is used for cases where a user email
and password should not be hard-coded or stored in a file or stored on a device. OAuth should also be used when
each device should have its own
unique security token that expires and needs to be refreshed frequently. GroveStreams is an OAuth 2.0
authorization server and can be used by other APIs such as Amazon's Alexa for authentication. More information
can be found on the GroveStreams OAuth Page.
GroveStreams will use the api_key token for API calls passed with both an api_key and a session token.
SSL
GroveStreams supports SSL. Change http to https in the Resource URL to secure your calls to GroveStreams: https://grovestreams.com/api
SSL encryption and decryption come with a performance cost. You will get better performance not using SSL if your data is not sensitive data and allows you to do so.
Request and Response Formats
The GroveStreams HTTP API uses JSON for almost all of its request and response body formats. Why does GroveStreams rely mainly on JSON?- GroveStreams is all about performance and JSON is faster and more scalable than XML
- JSON, when formatted, is a standard and is human readable
- JSON is supported by all major programming languages, all major browsers and is easy to work with (see www.json.org)
Compression
The GroveStreams HTTP API supports compression for request/response
bodies. We highly encourage using compression as it will make your
product and GroveStreams more scalable.
Add a request header "Accept-Encoding :
gzip, deflate" to your request and GroveStreams will return your
request compressed.
Add a request header "Content-Encoding :
gzip" to your request when the body is compressed as gzip.
Server-side Caching
The GroveStreams web servers will cache resource response requests for 10 seconds. This allows our servers to handle viral requests. The GroveStreams user interface frequently appends an argument called "_dc" with a unique number onto its API calls to avoid server caching for users with "Edit" rights.HTTP Request Errors
GroveStreams has two types of error codes. HTTP status codes and internal error codes. HTTP status codes come back as HTTP status code errors. GroveStreams internal error codes will be part of the response body along with a description of the actual error.GroveStreams Internal Error Codes
GroveStreams will map its internal error code with the following HTTP status codes:
| Internal Error Code |
HTTP Status Code |
Description |
| UNKNOWN_EXCEPTION | 500 |
Internal server error |
| ENTITY_MISSING | 404 |
Resource not found |
| SESSION_EXPIRED | 500 |
Session token expired due to inactivity. Watch for
SESSION_EXPIRED in the response body to determine if a user
should be re-authenticated. |
| RATE_LIMIT_EXCEEDED |
403 |
Call rate limit has been
exceeded. |
| ACCESS_DENIED | 403 |
session or api_key tokens do not have rights for the
action (PUT, POST, GET, DELETE) or resource (i.e. component,
cycle, unit, ...). |
| ENTITY_VALIDATION_FAILURE | 422 |
Resource failed validation during a PUT or SAVE. This
error will also return a list of all validation warnings and
errors. |
| CAPTCHA_VALIDATION_FAILURE | 422 |
Captcha challenge failed. |
| REQUEST_VALIDATION_FAILURE | 400 |
Slightly different than an entity validation error.
Usually caused by malformed uid keys or other types of parsing
errors. |
| EXPRESSION_PARSING | 500 |
Stream derivation expression parsing error. |
| EXPRESSION_EVALUATION | 500 |
Stream derivation expression evaluation error. |
| EXPRESSION_UNKNOWN | 500 |
Stream derivation unknown expression error. |
| OAUTH_TOKEN_EXPIRED | 400 |
OAuth2 access token expired. |
| OAUTH_INVALID_CLIENT | 401 |
OAuth2 invalid token. |
| OAUTH_INVALID_GRANT | 400 |
OAuth2 invalid grant. |
List of HTTP status codes
Sample Request Error:
This is an example of the response body when a session has expired.
HTTP status code was: 401 Unauthorized
Response Body was:
"message": "Session expired.",
"errCode": "SESSION_EXPIRED",
"success": false
This is an example of a "POST component" where the component definition had warnings and errors.
HTTP status code was: 422 Unprocessable Entity
Response Body was:
"message": "ERROR: '': Invalid name size. Range is
1 to 500 characters.<br>WARNING: '/Percent of Memory Used -
bytes/Variable/var1': Derived stream expression does not contain
dependent variable name 'var1'.<br>ERROR: '/Percent of Memory
Used (WOP) - bytes/Variable/free': Functions cannot be performed on
a stream base cycle.<br>",
"errCode":
"ENTITY_VALIDATION_FAILURE",
"validationResult": {
"validation": [
"message": "Invalid name
size. Range is 1 to 500 characters.",
"pathName": "",
"itemType": "component",
"valMsgType": "ERROR",
"itemUid":
"59d9d98d-bd17-4b7c-a99a-77b49fbad29b"
"message": "Derived
stream expression does not contain dependent variable name
'var1'.",
"pathName": "/Percent of Memory Used - bytes/Variable/var1",
"itemType": "stream",
"valMsgType": "WARNING",
"itemUid":
"c8886c4c-0b21-4722-b7ae-599c24374a1f"
"message": "Functions
cannot be performed on a stream base cycle.",
Memory Used (WOP) - bytes/Variable/free",
"itemUid":
"1999ddb7-25c0-4d5a-8835-b1c947049633"
"success": false
