Dashboards & Data Studio
Customizable dashboards, interactive charts, maps, and real-time stream views.
Build dashboards from a library of widget types — line charts, bar charts, gauges, grids, maps, and more. Every widget connects to live stream data and updates in real time. Customize colors, layouts, and branding to match your organization.
Dashboard Builder
The dashboard builder pairs a widget palette with a drag-and-drop canvas. Compose line charts, gauges, big numbers, tables, maps, and more — all wired to live stream data. Re-skin the result for any operational role with custom colors, layouts, and branding.
Dashboard designer showing the widget palette on the left and a 'Fleet Operations Command Center' dashboard composed of tables, multi-line charts, big-number widgets, and live trace charts
The dashboard designer — widget palette on the left, the canvas on the right, every widget bound to live streams.
Style It Your Way
Custom themes, colors, and layouts — configure the dashboard to match an operational role or brand identity.
Custom-themed dashboard with a green color scheme, gauges, big-number widgets, and a map — styled for a 'Canary Sensor' use case
Custom-themed dashboard — same widget set, distinct visual identity.
Charts & Gauges
Big-number widgets, gauges, multi-line charts, and trend graphs — all bound to live stream data, with synchronized time ranges and shared zoom across a dashboard.
Brewery Operations dashboard with mixed widget types — big-number tiles, four tank-temperature gauges, and multi-line charts for tank temperatures and gravity readings
Mixed widgets on a single dashboard — big numbers, gauges, multi-line charts, all wired to live streams.
Stream Selection & Drag-and-Drop
Drag streams directly from the component tree onto any widget — steel-series gauges, big-number tiles, level indicators, and plain bar gauges all accept the same drop. Threshold-aware widgets then shift color (green / yellow / red) based on configurable bounds, so the dashboard tells you what's wrong at a glance — including latency thresholds that flag stale data.
Brewery dashboard editor with annotated callouts — one pointing to streams being dragged from the component tree onto widgets (steel-series gauges, big numbers, level indicators, plain bar gauges), the other showing how to configure threshold colors and latency indicators
Drag streams from the tree onto widgets, then configure threshold colors and latency indicators — four widget types share the same drop target.
Gap Detection
Every stream tracks gaps natively — intervals where samples are missing relative to the expected cadence. Pick Base Gap Count or Base Non-gap Count as a roll-up statistic and chart the gap series alongside actuals to spot data-quality issues at a glance.
Solar Farm Operations dashboard with an annotated callout showing the Base Gap Count statistic option and a chart highlighting a daily gap-count spike with an arrow
Daily gap-count spike on a solar array — surfaced just by selecting Base Gap Count as the widget's value statistic.
Maps
Maps live alongside dashboards in the Content repository. Plot components and event locations across the world; drill into a marker to navigate to its component or trigger an action.
World map view from the Content repository — component and event locations marked across continents, with the Content tree on the left listing dashboards and the world map alongside them
A world map in the Content repository, plotting component and event locations — the same content tree that holds dashboards.
Pivot Tables
Group stream data by any dimension — component, folder, template, time period — and compute sub-totals and grand-totals on the fly.
Pivot Configuration & Chart Integration
Pivot table with row/column dimension selectors at the top and three multi-line charts beneath, showing aggregated stream data plotted alongside the pivot grid
Drag dimensions onto rows/columns and values onto cells. The pivot lives inside a dashboard, so synchronized charts plot the same aggregations.
Label & Value Filters
Filter rows by label (Equals, Begins With, Contains, Greater Than, Between…) or by aggregated value (Greater Than, Top N, Between…) — familiar from spreadsheet pivot tables, applied to live stream data.
Pivot label-filter submenu showing options: Equals, Does not equal, Begins with, Contains, Greater than, Less than, Between
Label filters — Equals, Begins With, Contains, Between, etc.
Pivot value-filter submenu showing options: Equals, Greater than, Greater than or equal to, Less than, Between, Top 10
Value filters — Greater Than, Top N, Between, etc.
Export
Copy widget contents to the clipboard or export directly to CSV or Excel from the widget menu.
Widget context menu showing Export to Spreadsheet (CSV), Export to Spreadsheet (Excel), Copy this Widget, and Settings options
Copy or export to CSV/Excel — one click from any widget.
Build Your Dashboard
From raw streams to polished dashboards in minutes.
SIGN UP FREE
