Explore Stream Selection
Streams can be drag and dropped from within studios or they can be
selected with the stream selection window.Select streams by navigating component folders: Double click a stream, highlight and click the add button or drag the stream to the right pane to select it.
![Stream Selection Via Tree Stream Selection Via Tree](../images/screen_shots/stream_picker/stream_picker_tree.jpg)
Select streams by their location on a map:
![Stream Selection Via Map Stream Selection Via Map](../images/screen_shots/stream_picker/stream_picker_map.jpg)
