GroveStreams Digi Cloud - Quick Start
This tutorial will walk through the creation of a GroveStreams user account, an organization, and the configuration of a Digi Command Monitor. The Command Monitor will push data from the Digi Device Cloud into your GroveStreams organization. Configure it to monitor the DataPoint event.
Step 1: Create a Free GroveStreams User Account and Organization
Open a browser and navigate to the GroveStreams registration page and sign up:
You will be prompted to create an organization. Select Yes:
Enter a name for the new organization. It can be any name. Click Create Organization:
Enter your new organization by clicking on its name:
The API Key, that the Digi Monitor will need to send data to the GroveStreams organization, can now be retrieved. The API Key is needed later in the tutorial:
Step 2: Create the Digi Monitor Command
Follow Digi's instructions to create a Monitor web service to monitor Device Cloud activity and push data to GroveStreams.Digi to GroveStreams Monitor Example:
<Monitor> <monTopic>DeviceCore,XbeeCore</monTopic> <monTransportType>https</monTransportType> <monTransportUrl>https://grovestreams.com/api/gtw/dgi/api_key/data</monTransportUrl> <monTransportToken>x:x</monTransportToken> <monTransportMethod>PUT</monTransportMethod> <monFormatType>json</monFormatType> <monBatchSize>100</monBatchSize> <monCompression>none</monCompression> <monBatchDuration>10</monBatchDuration> </Monitor>Important! Replace api_key with the api_key copied from above.
- monTrasnportType: Use either http and https.
- monTrasnportToken (uid/pwd) is ignored by GS so put anything in there like x:x.
- monTransportUrl: Replace the GS secret api_key between dgi and data. Append ?compTmplId=your_component_template_id onto the end of the URL to utilize component templates.
- monCompression: We support gzip compression. Not sure what Digi is doing. You can try with and without compression to see if it works.
Your component will land under the Components folder in Observation Studio. Refresh that folder to see if it has registered.
Congratulations! You have successfully created a Digi Cloud Command that uploads measurements into GroveStreams.
Click on the Dashboards tab to create dashboards and maps. Right click on the component and choose Edit Component to set your component's location, add stream units, create events with notifications, and change other properties. Keep exploring and learning!
Continue with the GroveStreams Temperature Example to learn more about how to make the most of your data with GroveStreams.
How it Works
The Digi Cloud pushes data to GroveStreams as it arrives.The data sent to GroveStreams arrives in Digi's cloud JSON format. The JSON includes the sample data, sample time, and several keys so that GroveStreams knows where to store the data being sent:
- api_key: This is included as part of the URL above and is your secret API key. It tells GroveStreams which organization the data will be inserted into and ensures the caller has the proper rights to make the call.
- id: This is the ID of a component within your GroveStreams organization that contains the stream that the data will go into. Component IDs need to be unique within an GroveStreams organization.
- streamId: This is the ID of the component stream which is used to place the data into. Stream IDs only need to be unique within each component.
- data: The sample data.
- timestamp: The sample date and time.
This example was made simple by allowing GroveStreams to create a default component with default streams. GroveStreams will do its best to determine if the stream type is a number, text, or boolean based on the first sample arriving. Users can view or modify existing component definitions by right clicking on them and selecting Edit Component. Modify any component attributes except the component and stream IDs. Consider using component templates to avoid having to edit every component after it registers.
Successful API calls to GroveStreams should return a status of: HTTP/1.1 200 OK.If the call made it to a GroveStreams server, but an error still occurred, a GroveStreams system notification will be created that contains the error. While in the GroveStreams organization's Observation Studio, click on the Notifications button located in the top toolbar (It looks like an envelope) and select the System tab. Click Refresh to list new notifications.
Any parameter that is part of the URL within the Command needs to be URL encoded. This should only become an issue if you have given any parameters a value with reserved URL characters (such as spaces or commas). There are many free URL encoders on-line that you can use to encode your URL or URL parameters such as freeformatter.com.
Having problems or you wish to modify the solution and are not sure what to do?
Post a question on our forum or send us an email and we'll do our best to help you out: support@grovestreams.comHelpful Links
GroveStreams Temperature ExampleGroveStreams Help Center
Digi Transport Protocol
Digi Monitor
